    Problem with PHP7 MySQL syntax highlight
    php7highlightingsyntaxmysql
    4 Posts 2 Posters 4.3k Views
    • Koppány AttilaK
      Koppány Attila
      Hi there,
      I’m using N++ latest version for editing PHP7 files. My problem is with the PHP7 MySQL command’s syntax as those commands are not highlighted. For example:
      • mysql_connect
      • mysql_query
      • mysql_close etc.
      these commands are highlighted, but the new PHP7 commands, e.g.:
      • mysqli_connect
      • mysqli_query
      • mysqli_close etc.
      these commands are not highlighted.
      If possible, how can I switch the syntax highlight on for these commands (and others), too?
      Thanks for your help.
      Regards,
      Attila
      • Koppány AttilaK
        Koppány Attila
        Hi there,
        Something has been missed…
        It would be also a good solution if I could import a PHP syntax highlight definition into N++ (then I’d append the PHP7 MySQL commands I’d use) but unfortunately I hadn’t found any XML file (UDL) to do that.
        Thanks.
        • Claudia FrankC
          Claudia Frank @Koppány Attila
          Hello @Koppány-Attila,
          Settings->Style Configurator->Language->php
          here you can customize the highlighting and if you click on word in Style two new boxes appear
          default keywords and user-defined keywords.
          Here ou can add your mysqli … words.
          • Koppány AttilaK
            Koppány Attila
            Hi Claudia,
            that’s just what I need! Thanks for your help, now it’s done and perfect!
            Have a nice day / evening!
            Attila
