    Running C program using gcc
    2 Posts 2 Posters 4.7k Views 2 Watching
    • Kaushal DokaniaK Offline
      Kaushal Dokania
      Hello
      I want to run my c programs via gcc compiler using notepad++
      i have installed gcc and it’s working from cmd
      I have already saved the following run shortcuts to do so :
      **compile **: alt+F9 : gcc -o “$(NAME_PART)” “$(FULL_CURRENT_PATH)”
      **execute **: ctrl+F9 : “$(NAME_PART)”
      but i can not execute my program… as nothing happens when i try do so so
      Please help how to solve this
        Claudia Frank @Kaushal Dokania
        Hello @Kaushal-Dokania,
        can gcc be found in path? If not you have to set the directory.
        Is the output a console application? If so, you need to call cmd shell together with compiled exe.
        For such thing I would recommend to install nppExec plugin which could do this in one run
        and if I remember correctly there even was an example how to do it with gcc.
