Notepad++ macro not working correctly
I have the TextFX plugin, and one of its functions is convert text to proper case.
I used the shortcut mapper and set the shortcut in the plugin commands tab.
The shortcut works without an issue but when I record it as a macro I get something that looks more like a serialized export.
Can anyone help me get this working?
Im having the exact same issue. I’ve also updated to the lates NP++ and its still happeneing. Very odd.!
I have noticed that “TextFX” has no [alt+] menu access short cut - for example [alt+F] = file menu. maybe the macro doen’t know where to get the commands from because tecnically there is no menu for TextFX?
Hello Walkerbo Belf and Lord Lethris,
Yes, you’re right ! Notepad++ does NOT handle the TextFX menus, properly and recording macros,that includes TextFX commands seems useless :-((
However, the following regex S/R can emulate the Proper Case feature :
Find what :
(\w)(\w*)Replace with :
\u\1\L\2Refer to the link, below, for explanations on the case modifiers
\uand\L:http://www.boost.org/doc/libs/1_48_0/libs/regex/doc/html/boost_regex/format/boost_format_syntax.html
And, here is, below, the corresponding macro, with the Alt + Ctrl + Shift + P shortcut, created in the shortcuts.xml configuration file :
<Macro name="Proper Case" Ctrl="yes" Alt="yes" Shift="yes" Key="80"> <Action type="3" message="1700" wParam="0" lParam="0" sParam="" /> <Action type="3" message="1601" wParam="0" lParam="0" sParam="(\w)(\w*)" /> <Action type="3" message="1625" wParam="0" lParam="2" sParam="" /> <Action type="3" message="1602" wParam="0" lParam="0" sParam="\u\1\L\2" /> <Action type="3" message="1702" wParam="0" lParam="640" sParam="" /> <Action type="3" message="1701" wParam="0" lParam="1609" sParam="" /> </Macro>So, as soon as you select the menu option Macro - Proper Case, or hit the corresponding shortcut, any selected text is changed, in a Proper Case way !
Refers to the documentation, below, for a detailed information :
http://docs.notepad-plus-plus.org/index.php/Editing_Configuration_Files#Search_.2F_Replace_encoding
Thus, you may insert all the lines, above, beginning by
<Action type="3", in that order, in an existing macro, to add a Proper Case action, on selected text, to this macro :-)).Just close N++, open Shortcuts.xml with an OTHER editor, save the changes and re-start N++ !
P.S. :
A)
Click on that link, below, for a discussion about the main capitalization rules :
https://notepad-plus-plus.org/community/topic/130/convert-case-to/4
B)
Let’s suppose the Test sentence, below :
You're very happy to spend a week in the Mary's cottageWith TextFX OR with my previous regex S/R, that sentence is changed into :
You'Re Very Happy To Spend A Week In The Mary'S CottageBut, if you prefer the nicer form, below :
You're Very Happy To Spend A Week In The Mary's Cottagejust use the following regex :
Find what :
'\w\w?\b|(\w)(\w*)Replace with :
(?1\u\1\L\2:$0)Notes :
This regex does NOT change all English contracted forms, as
'd,'ll,'m,'re,'s,'t,'ve, … -
If a contracted form is matched, as group 1, in the second part of tha alternative does NOT exist, it is just rewritten (
$0) as is -
If a classical range of word characters are matched, group 1 exists and the word is changed :
With its first letter, in uppercase way (
\u\1) -
With its subsequent letters, in a lowercase way (
\L\2)
I have the same problem, but I am using TextFX unescape “” to ". Any solution for this problem?
Hello, @tarek-faham,
I’m a bit surprised because this kind of replacement is quite easy to process, even in
normalsearch mode !SEARCH
""REPLACE
"giving the new macro :
<Macro name='UnEscape "" to "' Ctrl="no" Alt="no" Shift="no" Key="0"> <!-- Macro NAME & possible SHORTCUT --> <Action type="3" message="1700" wParam="0" lParam="0" sParam="" /> <!-- Initialization S/R --> <Action type="3" message="1601" wParam="0" lParam="0" sParam='""' /> <!-- SEARCH "" --> <Action type="3" message="1625" wParam="0" lParam="0" sParam="" /> <!-- NORMAL search mode --> <Action type="3" message="1602" wParam="0" lParam="0" sParam='"' /> <!-- REPLACE " --> <Action type="3" message="1702" wParam="0" lParam="768" sParam="" /> <!-- or 512, if NO Wrap-around --> <Action type="3" message="1701" wParam="0" lParam="1609" sParam="" /> <!-- Replace All, in CURRENT file --> </Macro>Best Regards,
