    Different syntax highlighting for function declaration and body
    1 Posts 1 Posters 1.6k Views 1 Watching
    • Moran AlriyamiM Offline
      Moran Alriyami
      Is it possible to make notepad++ highlight a function header / declaration differently than its body?
      For example :
      https://i.github-camo.com/97e761a5504bbc57b3e8efdd89a218439a5f20ae/68747470733a2f2f636c6f75642e67697468756275736572636f6e74656e742e636f6d2f6173736574732f373237353632322f31303730393932302f34666237666634612d376134382d313165352d383331632d3738653366643038313262352e706e67
      As opposed to :
      https://bembengarifin.files.wordpress.com/2014/12/notepadpluspluswholescreen1.jpg
      Where you can see that the quicksort body and header has the same colours(aside from the keyword Where).
