    Need help for Search and replace feature TX
    2 Posts 2 Posters 2.1k Views 2 Watching
    • michel buartM Offline
      michel buart
      I have a TXT file containing 10000 lines.
      I need to find a string like: “Example_table on every data”
      And replace it by:
      Example_Table
      On every data
      Means the result must be in two lines not one.
      I cannot find how to do that “easily” with search and replace.
      Thanks in advance for your help.
      • Peter StotzP Offline
        Peter Stotz
        Hi, michel buart
        Open the Replace dialog (CTRL + H)
        Find what: Example_table on every data
        Replace with: Example_table\r\nOn every data
        check enhanced mode \r \n \t \x …
        peter
