    How to make Notepad++ have a Launch in Edge
    launchbrowser helpmicrosoft edgebrowseredge
    1 Posts 1 Posters 10.9k Views 2 Watching
    • Putrid Carcass75P Offline
      Putrid Carcass75
      How to add Launch in Edge in Notepad++
      -TFleck
      METHOD 1 (Short Version)
      1. Find “shortcuts.xml” (usually in C:\users\ %username%\appdata\roaming\notepad++)
      2. Edit the file.
        Then copy and paste this under “<UserDefinedCommands>”
        <Command name=“Launch in Edge” Ctrl=“no” Alt=“no” Shift=“no” Key=“0”>$(FULL_CURRENT_PATH) &quot ;microsoft-edge:// "</Command>
      3. Save, then open or restart Notepad++
        METHOD 2 (Longer Version)
      4. Find “shortcuts.xml” (usually in C:\users\ %username%\appdata\roaming\notepad++)
      5. Edit the file.
        Then copy and past one of the commands under “<UserDefinedCommands>”
        (for example the firefox launcher command)
        <command name=“Launch in Firefox” Ctrl=“yes” Alt=“yes” Shift=“yes” Key=“88”>firefox "$(FULL_CURRENT_PATH)"</Command>
      6. Change the following attributes:
        “Launch in Edge”
        Ctrl=“no”
        Alt=“no”
        Shift=“no”
        Key=“0”
      7. Next change the command:
        Original= >firefox "$(FULL_CURRENT_PATH)"<
        New Command= >$(FULL_CURRENT_PATH) &quot ;microsoft-edge:// "<
      8. Restart Notepad++
        NOTE - You edit your attributes through modifying the shortcut in the “Run” dropdown menu in Notepad++.
        Also be sure to add the space before and after the &quot on the FULL_CURRENT_PATH side, as well as
        the space after the // on the edge side.
