Uncomment selection using "ctrl+alt+shift+R" does not work. Taking to some other page in web explorer.
Uncomment selection using “ctrl+alt+shift+R” does not work.
When commented using short cut for comment selection “ctrl+alt+shift+C”.
Hey Ankita,
I am also facing same problem with notepad ++… :( :(
But there is a strong workaround available , you can use “ctrl+shift+Q” for Comment selection and “ctrl+shift+K” to Uncomment selection.
CTRL-ALT-SHIFT-R
andCTRL-ALT-SHIFT-C
are defined by the XML Tools plugin to do XML(!) commenting and uncommenting.Unfortunately
CTRL-ALT-SHIFT-R
is also bound to the run command “Launch in Chrome” which takes precedence over the plugin-command.Also unfortunately NPP does not detect and warn about multiple shortcut assignments. So you need to check your shortcut settings and adjust them to your liking.
