    Using different configs
    3 Posts 3 Posters 2.9k Views 2 Watching
    • wiesodennW Offline
      wiesodenn
      I know this from Total Commander where I can start TC defining a different set of configs on the commandline ( /i=name.ini ).
      Is there anything similar I coud do with NP++?
      E.g. notepad++.exe --config:"c:\users\SomeUser\AppData\Roaming\Notepad++\config.xml
      Or does anyone know of a workaround for this?
      I usually work on a multiuser environment where NP++ and TC are installed for all users. All users have their own configs for TC and NP++ in %AppData%. It happens, that I have to start TC with elevated rights (as admin) and in order to still use my defined settings I start TC elevated with the mentioned switch showing to my personal config.
      From TC I often have to edit files using NP++. But when starting NP++ from TC, NP++ inherits the settings defined for the admin account.
      Does anyone know of a way or workaround to start NP++ in my example with a set of different configs (probably my personal ones)?
        Claudia Frank @wiesodenn
        @wiesodenn
        can tc do something like runas?
        Or maybe using links if admin doesn’t need to have it’s own config?
        • glennfromiowaG Offline
          glennfromiowa
          This question is old, but I just stumbled across it and also just learned the answer to it: In the Settings menu, select Preferences, and then the Cloud group. Click on the radio button Set your cloud location path here: and then enter your AppData path in the text box. You’ll have to restart Notepad++, but after that, it should pull the settings from your AppData path instead of the Admin path.
