    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Need help with a Case Problem
    Help wanted · · · – – – · · ·
    • Fredrick Bass
      Fredrick Bass last edited by
      I am trying to write code for the following instructions:
      create a style rule to set the width of each div element of the row class to 100% of its container, displaying the row only when it’s clear of floated content on both margins.
      this is the code I’ve written, could someone tell me if I am heading in the right direction
      div.row {
      width: 100%;
      clear: both;
      Claudia Frank 1 Reply Last reply Reply Quote 0
      • Claudia Frank
        Claudia Frank @Fredrick Bass last edited by
        @Fredrick-Bass
        the first thing you should note is that this is a notepad++ and
        not a whatever development language forum.
        Also this is the case, we are not taking this to serious but to
        make it easier for one to help you, you should consider to give as
        much informations as possible. Question which comes instantly in to my mind
        when reading your post is something like - what programming language is he using??
        Do you agree?
