    cursor movement in right-to-left mode
    arrow keyscursor movementright-to-left
    8 Posts 4 Posters 7.3k Views 4 Watching
    • Nir NagidN Offline
      Nir Nagid
      Hi everyone,
      Arrow key navigation seems to be defined so that right arrow always moves the cursor FORWARD. This is counter-intuitive in RTL mode, as “forward” is now in the LEFT direction, and all other programs I know work that way. Would the developers consider changing this? In the meantime, can anyone help with a workaround? I.e. can the arrow keys be mapped differently for RTL and LTR modes?
      Thank you very much,
      Nir
        Claudia Frank @Nir Nagid
        @Nir-Nagid
        you could do it with a python script
        _g = globals()        # global variable used to check status
        if not _g.get('SWITCHED_TO_RTL'):                                               # if variable not defined yet,
            SWITCHED_TO_RTL = False
        def main():        # main function to handle start/stop behavior
            global SWITCHED_TO_RTL                                                      # assining to global variable
            if SWITCHED_TO_RTL:                                                         # if currently in RTL mode
                SWITCHED_TO_RTL = False                                                 #   set flag to False
                editor.assignCmdKey(KEYS.RIGHT,2306)                                    #   and remap arrow and
                editor.assignCmdKey(KEYS.LEFT,2304)                                     #   left arrow key to default
                notepad.menuCommand(MENUCOMMAND.EDIT_LTR)                               #   change view mode back to LTR
            else:        # else
                SWITCHED_TO_RTL = True                                                  #   set the flag to true
                editor.assignCmdKey(KEYS.RIGHT,2304)                                    #   and remap arrow and
                editor.assignCmdKey(KEYS.LEFT,2306)                                     #   left arrow key
                notepad.menuCommand(MENUCOMMAND.EDIT_RTL)                               #   change view mode to LTR
        main()
        When running the script for the first time it remaps the left and right arrow key and changes the view to RTL,
        next run would reverse the changes.
          Nir Nagid
          Thank you very much Claudia, but I since realized the problem goes deeper (or is the following a separate problem?). The “push” mechanism for RTL languages in LTR mode is a bit screwy. Here’s an example: make sure you’re in LTR mode; on a blank line, enter “א”, space, “1”; on anther, enter “1”, space, “א”. Both lines look the same: “1 א” :(.
          Also, if you select the first letter in the first line, it LOOKS like the 1 is selected, but cut’n’paste it, and you’ll find the “real” first char, “א”, is the one that was selected.
          Developers? Workaround? Any other insights?
          Thank you,
          Nir
          • DaveyDD Offline
            DaveyD
            I’ve been working with this problem for years now… Never found a workaround - I’d love it if there was, however, it seems like most programs have this problem. Microsoft Word is one of the only programs that deal with this excellently!
              @Nir-Nagid
              I think this is a problem of some of the lexers because if I try to do it and having python as language set it doesn’t happen.
              But if I have normal text as language, then it happens. You can workaround it by defining an empty udl and use it as “YOUR_NORMAL_TEXT”.
              Btw I guess there is a need to have more shortcuts reassigned. The once, I think, are useful are
                      SWITCHED_TO_RTL = False                                                     #   set flag to False (default)
                      editor.assignCmdKey(KEYS.LEFT, 2304)                                        #   char left
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.SHIFT << 16), 2305)                 #   char left extend
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.SHIFT + KEYMOD.ALT << 16), 2428)    #   char left rect extend
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.CTRL << 16), 2308)                  #   word left
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.SHIFT + KEYMOD.CTRL << 16), 2309)   #   word left extend
                      editor.assignCmdKey(KEYS.RIGHT, 2306)                                       #   char right
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.SHIFT << 16), 2307)                #   char right extend
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.SHIFT + KEYMOD.ALT << 16), 2429)   #   char right rect extend
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.CTRL << 16), 2310)                 #   word right
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.SHIFT + KEYMOD.CTRL << 16), 2311)  #   word right extend
                  else:        # else
                      SWITCHED_TO_RTL = True                                                      #   set the flag to true (RTL mode)
                      editor.assignCmdKey(KEYS.RIGHT, 2304)                                       #
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.SHIFT << 16), 2305)                #
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.SHIFT + KEYMOD.ALT << 16), 2428)   #
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.CTRL << 16), 2308)                 #
                      editor.assignCmdKey(KEYS.RIGHT + (KEYMOD.SHIFT + KEYMOD.CTRL << 16), 2309)  #
                      editor.assignCmdKey(KEYS.LEFT, 2306)                                        #
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.SHIFT << 16), 2307)                 #
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.SHIFT + KEYMOD.ALT << 16), 2429)    #
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.CTRL << 16), 2310)                  #
                      editor.assignCmdKey(KEYS.LEFT + (KEYMOD.SHIFT + KEYMOD.CTRL << 16), 2311)   #
                      notepad.menuCommand(MENUCOMMAND.EDIT_RTL)                                   #   change view mode to RTL
              main()
              • YaronY Offline
                Yaron
                Hello all,
                @Claudia,
                Welcome back. :)
                And thanks for the script.
                Two comments:
                1. editor1 and editor2 if you want to apply the keys to both views.
                2. Ctrl + (reassigned) Arrow does not work properly when using a RTL language in LTR mode (and vice versa).
                @Nir,
                Scintilla does not fully support RTL. We should raise the issue there more frequently.
                @Davey,
                EditPad is quite a good editor which fully supports RTL and bidi.
                You can set the behavior of the left/right arrows in Options -> Configure File Types -> Editor Options -> Default text layout -> Edit.
                (I use the PRO version).
                InsertText
                Best regards.
                • DaveyDD Offline
                  DaveyD
                  @Yaron,
                  Hi and thanks for the suggestion.
                  My problem is that I am referring to coding - i.e., in my code I have Hebrew text (e.g. messages, dialogs etc.) and it’s extremely difficult to work with!
                  So, since I use n++ for coding (as I developed a custom syntax using UDL2 as well as functions hints and function list), using editPad is not really relevant in my case… unless there’s more there than I expect… :)
                  Thanks,
                  David
                  • YaronY Offline
                    Yaron
                    Hello David,
                    You’re welcome.
                    NPP is undoubtedly a great editor. Combining Latin and Hebrew, however, is much easier with EditPad.
                    It is a developer editor and you can set a custom syntax highlight.
                    I use a toolbar button in both editors to open the current file (and line) in the other editor.
                    In NPP:
                    <Command name="פתח ב- EditPad..." Ctrl="no" Alt="no" Shift="no" Key="0">&quot;C:\Program Files\EditPad Pro\EditPadPro7.exe&quot; &quot;$(FULL_CURRENT_PATH)&quot; /l$(CURRENT_LINE)</Command>
                    and in EditPad:
                    "C:\Program Files\Notepad++\NP\notepad++.exe" "%FILE%" -n%LINE%.
                    Best regards.
