    i know this must seem simple but i need help with regex (formula)
    4 Posts 1 Posters 2.4k Views 1 Watching
    • Joe BlowJ Offline
      Joe Blow
      I need a formula to find the value of Energy from say 100.0000 and change it to say 999.0000
      http://www.filedropper.com/example1
      file Is above, If needed.
      • Joe BlowJ Offline
        Joe Blow
        ok…nevermind, I finally figured out a crude formula
        Energy \K.+(?= )
        it knocks some spaces out in middle of the lines…but it seems to load up and work for me anyway…I really need help with my other post though…
        https://notepad-plus-plus.org/community/topic/12129/need-help-with#
        really HAVE to have help with that issue…
        • Joe BlowJ Offline
          Joe Blow
          ok … turns out I was wrong about my crude formula, it doesn’t seem to pick up every energy value ;( … back to square one on this one…need a easy fix…what did I do wrong, what better way is there?
          • Joe BlowJ Offline
            Joe Blow
            Ok figured that one out as well…thanks all that helped over these few months
