    Html problems
    3 Posts 2 Posters 2.9k Views 2 Watching
    • Adrian Parkash SuriA Offline
      Adrian Parkash Suri
      HI,
      I think I have installed two plugins which do the same thing in Html complete tags now does it twice
      <p> test </p> </p>
      for example, any ideas how to fix it
      Regards
      Adrian Suri
      • J Offline
        Jim Dailey
        @Adrian-Parkash-Suri
        Delete or move one of the plugin’s DLL files from your plugins directory?
          Adrian Parkash Suri
          Sorry y mistake it wasn’t a duplicate plugin I had html auto complete on
          in preferences/auto-completion turned on and also had web-edit, at the same time
          thanks
          Adrian
