    Questions about Notepad++ project
    3 Posts 2 Posters 2.4k Views 2 Watching
    • Ahmed S. M. MadhunA Offline
      Ahmed S. M. Madhun
      Hallo,
      I am trying to find information about Notepad++ procject, but not the software it self.
      Like how can someone join the development team?
      What standards should someone that joined the team take care of?
      how to submit a bug report ? and how will it be fixed ?
      What kind of system engineering process are Notepad++ using (like: Scrum, Kanban, XP, WaterFall)
      How are the people in the project organized ? in small groups or big ?
      This kind of info.
      If any one can help it will be awesome
      thanks.
        Claudia Frank @Ahmed S. M. Madhun
        @Ahmed-S.-M.-Madhun
        I assume those two links answer your questions.
        https://github.com/notepad-plus-plus/notepad-plus-plus
        https://github.com/notepad-plus-plus/notepad-plus-plus/blob/master/CONTRIBUTING.md
          Ahmed S. M. Madhun
          Thanks … will search there
