    Plugin Emmet does not work
    emmetpluginpythonscript
    5 Posts 2 Posters 6.5k Views 2 Watching
    • fromilliaF Offline
      fromillia
      Plugins ‘Emmet’ and ‘Python Script’ have been donloaded with ‘N++ plugin manager’.
      Plugin Emmet doesn’t work: after using hot key combination (or clicking comand in Plugin menu) got a messeges ‘unknown exception’ and ‘Python script plugin did not accept the script’
      WTF ?
        Claudia Frank @fromillia
        @fromillia
        unknown exception points to a unsuccessful installation of python script.
        I would recommend downloading the msi from here and do an install.
        I assume that emmet will work once pythonscript plugin has been installed successfully.
        fromilliaF 1 Reply Last reply Reply Quote 0
          fromillia
          Thanks but i’ve tried this metod: not working (I chose “repair”).
          Also i’ve tried to unpack “PythonScript_full_1.0.8.0.zip” to main directory (Notepad + +) but i have no permission for this (have to choose ANOTHER directory for unpack).
          PS
          I’ve tride those after reinstalled Npp
            fromillia @Claudia Frank
            @Claudia-Frank
            Thanks but i’ve tried this metod: don’t working (I chose “repair”).
            Also i’ve tried to unpack “PythonScript_full_1.0.8.0.zip” to main directory (Notepad + +) but i have no permission for this: have to choose ANOTHER directory for unpack (button with administrator’s rights is NOT the point, because i’m administrator)
            PS
              fromillia
              THE PROBLEM SOLVED
              Total commander helps to unpack ZIP to main directoty of Np++
