    How to change max column number of find result panel?
    find resultmax column
    4 Posts 3 Posters 3.1k Views
    • JG ShiJ
      JG Shi
      Currently, find result panel seems only support 1000 byte per line, if to long should be cut.
      can i change this limited?
      • JG ShiJ
        JG Shi
        Anyone know how to change it ? it is very useful, all search result can be copy from the find result panel , but line length limited.
        • Claudia FrankC
          Claudia Frank @JG Shi
          @JG-Shi
          afaik this isn’t a parameter which can be configured by gui.
          • Scott SumnerS
            Scott Sumner
            Perhaps the LineFilter2 or Analyse plugins might be of assistance here. They might be better than the Find Result panel at preserving really long lines.
