Help with NppExec!!!
I am having some trouble with the NppExec plugin. I installed it and followed all the instructions for setting it up, but when I try to compile or run a simple Java program 2 errors show up in the console. 1. Error: could not find java.dll, and 2. Error: could not find Java RE Runtime Environment. I have all of the latest Java updates. I have downloaded every Java program I could think of, and ran some troubleshooter, and nothing has worked. I am at a loss.
you followed the manual?
4.7.2. Compiling Java ??
Did you double check if java environments variables really exists ? Like %JAVA_HOME%?Cheers
