    how to arrange in ascending order
    8 Posts 4 Posters 11.5k Views 1 Watching
    • Neto BezerraN Offline
      Neto Bezerra
      Hi, guys. I have a doubt: there is how to arrange in increasing order the months and years?
      https://1drv.ms/i/s!AjClnevQ_1BJg7ly2EvPzDLZ00GTQQ
      Thankssss
      • Binnu Jesudasan GudapatiB Offline
        Edit > Line Operations > Sort Lines As Integers Ascending
          Hello Neto Bezerra and Binnu Jesudasan Gudapati,
          Binnu, I don’t think that’s exactly the sorted list of dates that would like Neto ! Indeed, from the original example list of dates, below :
          11/2011
          04/2013
          08/2012
          01/2011
          05/2014
          03/2013
          10/2012
          if we perform the sort Edit > Line Operations > Sort Lines As Integers Ascending, we obtain :
          01/2011
          03/2013
          04/2013
          05/2014
          08/2012
          10/2012
          11/2011
          It’s easy that this list is not sorted by year :-(( But you can easily sort a list of dates, if your remember one important rule :
          Write the different items of the date, from left to right, from the less frequently changed item to the more frequently changed item
          In our case, as years changed less frequently than months, we must re-organize the list, according to the template year/month. To do so, just use the following S/R, in Regular expression mode :
          SEARCH : (\d+)/(\d+)
          REPLACE : \2/\1 or $2/$1
          Therefore, from the original example, above, we get, after the S/R, the new list :
          2011/11
          2013/04
          2012/08
          2011/01
          2014/05
          2013/03
          2012/10
          Finally, we perform the classical sort Edit > Line Operations > Sort Lines Lexicographically Ascending, to obtain the well-sorted list ( to my mind ! ), below :
          2011/01
          2011/11
          2012/08
          2012/10
          2013/03
          2013/04
          2014/05
            Scott Sumner
            Perhaps the OP needs the data to be in the
            MM/YYYY
            format after the sort.
            Simply performing again guy038’s regex search and replace will do that.
              Hi Scott,
              Oh yes ! I forgot that final point ! Thanks for your reply !
                Neto Bezerra
                Thanks so much, guys!!!
                  Neto Bezerra
                  Guys, there is a possibility to put some kind of marking or space for when happening a break in the sequence?
                  Example:
                  2011/03
                  2011/04
                  2011/05
                  2011/07
                  2011/08
                  2012/01
                  2012/02
                  Thank you very much in advance!!
                    Scott Sumner
                    You need to do some programming in order to achieve that.
