    XML Tools - Validation Issue
    failed to locatxml schemaxml toolsvalidation
    4 Posts 4 Posters 6.8k Views 2 Watching
    • Patrick DawsonP Offline
      Patrick Dawson
      Trying to use XML Tools to validate an xml file. Get the error: "Failed to locate the main schema resource at <URL>. When I click on the URL specified, I can access it in a browser with no issues. I’m thinking it may be an issue somewhere with trusting the site. Can anyone offer advice on how to get past this error?
      Thanks,
      Patrick
      • Andreas WeberA Offline
        Andreas Weber
        I have the same problem. Any comment would be great.
        Thanks.
          Claudia Frank @Andreas Weber
          @Patrick-Dawson
          @Andreas-Weber
          first check if you are using the latest version and if so,
          maybe @morbac can help if you can provide an xml file in question.
          • w3artwW Offline
            w3artw
            This seems to be an issue with the https / TLS connection - at least in my case it works fine without https in front - with https I receive this error.
            Maybe this can be fixed easily in the next version.
            Thanks, Mark
