    • Categories
    • Recent
    • Tags
    • Popular
    • Users
    Use regex to replace backspace by underscore
    Help wanted · · · – – – · · ·
    7.5k
    • Mauricio SalazarM
      Mauricio Salazar
      Hi everybody I have a csv file in which I would like to make the following replacement:
      Input:
      Word, Word
      Output:
      Word_Word
      I want to replace words with the following characteristics:
      1. Longer than four characters
      2. The first word ends with a comma
      3. There is a backspace between the words
      I tried this regular expression with the TextFX, but I did not work:
      Find:
      ^[A-Za-z],{3,23}$\b^[A-Za-z]{3,23}$
      Replace:
      ^[A-Za-z],{3,23}$[_]^[A-Za-z]{3,23}$
      Thank you
      gerdb42G 1 Reply Last reply Reply Quote 0
      • gerdb42G
        gerdb42 @Mauricio Salazar
        With NPPs Search&Replace you would use ^(\w{5,}),\x08(.*)$ to search and $1_$2 for replacement. This will search for any word at the beginning of a line which is 5 or more characters long and is followed by a colon followed by a backspace. Both the word and the remainder of the line are grouped. In the replacement, the word followed by an underscore followed by the rest of the original line is used.
        You may want to read about the Regular Expression syntax here for searching and here for replacing.
        • Mauricio SalazarM
          Mauricio Salazar
          Thank you for your help, but I wonder if I am applying the regex correctly.
          http://postimg.org/image/tb98dqnf7/
          As you see in the image I did not change. With “NPPs Search&Replace” you meant a plug in.
          Thank you
          • dailD
            dail
            From your image, it doesn’t look like there is a backspace after the comma.
            • Mauricio SalazarM
              Mauricio Salazar
              You are right, is was a noob error backspace ≠ whitespace,. So I followed this post, link, that suggest using: (\s).
              Alt text
              Could you please help me changing the regex from backspace to whitespace?
              Best Regards
              • dailD
                dail
                ^(\w{5,}),\s(.*)$
                Instead of \x08 which represents 1 backspace character you just use \s which is a single whitespace chracter.
                • Mauricio SalazarM
                  Mauricio Salazar
                  Thank you, it worked well
                  Best Regards
