    Unable to select 64-bit Notepad++ default for file formats
    1 Posts 1 Posters 1.8k Views 1 Watching
    • Bisher BasB Offline
      Bisher Bas
      Using 64-bit Windows 7.
      I right click on the file, select Open With, choose default program, Browse, select C:\Program Files\Notepad++\notepad++.exe, select Open. However, Notepad++ does not show up in the “Open With” dialog.
      Can you help?
