    Several 64-bit plugins relesed
    6 Posts 5 Posters 46.8k Views 3 Watching
    • Franco StellariF Offline
      Franco Stellari
      I have released a 64-bit version of my plugins at https://sites.google.com/site/fstellari/nppplugins
      AutoSave v1.50
      LanguageHelp v1.70
      MenuIcons v1.20
      OpenSelection v1.10
      RunMe v1.40 (added passing parameters to scripts)
      TakeNotes 1v20 (fixed new note encoding issue)
      TopMost 1v40
      On a separate note, is anybody maintaining a list of available 64-bit plugins… where?
      Thank you and regards,
      Franco
      • chcgC Offline
        chcg
        see https://notepad-plus-plus.org/community/topic/12483/new-version-of-plugin-manager-for-testing/2
        • YaronY Offline
          Yaron
          Hello Franco,
          Thank you for your work.
          I find the MenuIcons plugin very useful. Highly recommended.
          Hello chcg,
          Thank you for your contribution to the Compare Plugin 64-bit version.
          Best regards.
          • cmeriauxC Offline
            cmeriaux
            @Franco-Stellari Hello Franco, I try to use MenuIcons when french language is activated. It not very convenient to switch configuration from english to french.
            I try to use “CMD ID match” option but the migration is very painfull to.
            Do you have a suggestion to do it easily ?
            What if your plugins load the nativeLang.xml ?
            Thanks
            Franco StellariF 1 Reply Last reply Reply Quote 0
              Franco Stellari @cmeriaux
              @cmeriaux I’m not sure that loading the xml file will help since one still need to rename the files.
              I guess somebody has to take the plunge and rename the files with the ID, possibly writing a script to extract them from the XML file.
              I chose not to use ID because it makes it much easier to identify the icons and also allows to add icons to menu that don’t have an ID.
              For example if you create a File.ico in the main folder it will add an icon to the main menu as well.
              I don’t have an XML parser so I would have to do the conversion manually as well.
              • Кирилл ФроловК Offline
                Кирилл Фролов
                You have typo in the word released you wrote relesed
