    Macro Sharing Help
    4 Posts 3 Posters 3.1k Views
    • Roberto TentiR
      Roberto Tenti
      I can’t figure out how to give or send a macro that I’ve created to another user. It looks like it cannot be done. Is there a quick way? If so, can someone please provide a step by step process? Thank you in advance
      RT
      • Scott SumnerS
        Scott Sumner
        Not exactly a detailed step-by-step, sorry, but I see my macros in the <Macros> section of the shortcuts.xml file. The basic idea would be to copy the text between the desired macro start (“<Macro”) and the macro end (“</Macro>”), inclusive into someone else’s shortcuts.xml file in the Macros section.
        • cmeriauxC
          cmeriaux
          Yes this is the good solution . Dont forget to edit xmf file while npp is closed.
          • cmeriauxC
            cmeriaux
            xmf => xml
            sorry for the Typo, I should’nt write on my smartphone
