    Is there a way to copy and paste onto multiple lines without displacing text?
    4 Posts 2 Posters 30.8k Views 1 Watching
    • Paul TinkleP Offline
      Paul Tinkle
      So I think it’s best just to provide an example cause it’s hard to explain
      so Imagine I have
      and I need to copy four items one on each line
      Is there a way to do so without it becoming
      1 item
      item
      item
      item
      4?
      and rather
      1item
      2item
      3item
      4item?
        Scott Sumner
        I’m really uncertain as to what you’re asking about, but…as long as your paste-point is in the same column in the multiple lines (like it is in your example above), all you have to do is obtain a “column caret” and do the paste.
        For example, put the caret to the right of the “1” in your example. Press Shift+Alt+DownArrow three times (this will give you a column-caret on the four lines after the numbers. Then…paste. Whatever is in the clipboard (which is hopefully without line-endings) will appear on each line after the number that is already there.
        If I’m off-base about what you’re asking for, I’m sorry, and could you please clarify?
          Paul Tinkle
          Alright I’ll try and clarify
          so I have two documents, I’ll show some of whats on them
          the first one is
          1|
          2|
          3|
          and so on
          the other one is
          Long Island
          Brooklyn
          Manhatten
          Now I want to copy the three of those and paste it so that only one goes on each line so that it’s
          1|long island
          2|brooklyn
          3| Manhatten
          instead of
          1|long Island
          brooklyn
          Manhatten
          2|
          3|
            Scott Sumner
            Ah, okay…in your first posting all the things to paste in were the same (“item”). Since they are actually different, copy them as a column block from their source (hopefully also Notepad++) using Shift+Alt+arrows to define the column block, and invoke copy. Then, at the intended destination, on the first line, invoke a paste.
