    can some one help me unscramble a PNG??? need help
    2 Posts 2 Posters 2.5k Views 1 Watching
    • dirtbikekid134 _D Offline
      dirtbikekid134 _
      can some one help me ?? with unscrambling a png???
      • Js jSJ Offline
        Js jS
        you have to google the “png file format specification”, then open your png file using Notepad++
        using the hex plugin, check that the format of your png file matches the specification.
        if it does not match, then make the necessary corrections.
        keep saving after every correction, and viewing the result.
        using this method, it should take no more than 20 years to fix your file, depending on the size of the file, of course.
        or …
        you could submit your post someplace that deals with file recovery, not a place that discusses text editing.
