    python script: additional chars and smarthighlight
    9 Posts 3 Posters 5.3k Views 2 Watching
    • Gytis MikuciunasG Offline
      Gytis Mikuciunas
      I’m using python script plugin and it works quite well for my basic usage.
      What I want to do, is to highlight word/string with the mouse double click and use smart highlighter to colorize all the same words/strings in text on the same tab.
      As I’m using additional chars and this script, smart highlighter doesn’t work for words with additional chars:
      def extendWordChar():
      additionalChars = ‘:._-’
      chars = editor.getWordChars()
      if additionalChars not in chars:
      editor.setWordChars(chars + additionalChars)
      def callback_READY(args):
      extendWordChar()
      def callback_BUFFERACTIVATED(args):
      extendWordChar()
      notepad.clearCallbacks([NOTIFICATION.BUFFERACTIVATED ])
      notepad.callback(callback_BUFFERACTIVATED, [NOTIFICATION.BUFFERACTIVATED ])
      notepad.callback(callback_READY, [NOTIFICATION.READY ])
      thx in advance
        Scott Sumner @Gytis Mikuciunas
        @Gytis-Mikuciunas
        I find that if I execute the following code, then double-clicking anywhere in the comment line smart-highlights everything between the first ‘a’ and the final ‘e’…so it appears to work for me:
        new_word_chars = '-:.'
        for c in new_word_chars:
            if c not in editor.getWordChars(): editor.setWordChars(editor.getWordChars() + c)
        # abc-def-ghi.aaaa:eeeee
          Gytis Mikuciunas
          Hi Scott,
          Script that I’m using and your script highlights word/string.
          But notepad++'s feature “smart highlighter” highlights (green color by default) all the same words/strings in current tab. And it doesn’t work for words/strings with my additional chars.
          So I need to force it somehow via python script I guess.
          • C Offline
            cmeriaux
            hello @Gytis-Mikuciunas
            have you try the function “Search”/“mark all”/“using 1st style” (or other style) or through the contextual menu “style token”/“using 1st style” (could be map to a shortcut)
            It’s highlight whatever you want including your extended word chars
              Gytis Mikuciunas
              This is not a solution for me to use shortcuts etc.
              If it’s working by default why I need to do manual searching, marking.
              very handy when you double-click on some word or string and can see immediately if it repeats somewhere.
              I hope that Claudia Frank will look into my posts :) She always has good script related ideas and solutions :)
              • C Offline
                cmeriaux
                You can mention Claudi Franck directly so that he’ll get a notification
                @Claudia-Frank
                  @Gytis-Mikuciunas
                  Adding more copies of the pseudo-word from my little test script to the editor window and then getting the smart highlighter to invoke…turns bright green ALL copies of the same pseudo-word string.
                  I seem to recall some problem/issue with setting the word characters with an earlier version of N++; I think it was @dail that pointed this out to me in a posting that I can’t find at the moment. I’m currently running N++ 7.1 x86 and this type of word-character change in combination with the Smart Highlighting works there.
                    @Gytis-Mikuciunas
                    I found the posting I mentioned: https://notepad-plus-plus.org/community/topic/12186/select-variables-with-dollar-sign-in-php-scripts
                    @dail indicated there that the version must be > 6.8.3
                    As that is quite old, I’ll presume that you are running something newer and that there is some other reason for your trouble…I just don’t know what it is.
                      Gytis Mikuciunas
                      Scott, you’re right.
                      I have updated my noteped++ to the newest version and now it works as expected.
                      thx a lot!!!
