    Installation of plugins with Notepad ++ 64 bit
    kutschehelloi would
    2 Posts 2 Posters 5.9k Views
    • Jens KuszewskiJ
      Jens Kuszewski
      Hello, I would like to install Pluggins under the 64 bit version. For example, Compare Plugin. Everything I’ve found about google did not work.
      Do I now again have to install a 32 bit version or what should I do?
      greeting Kutsche
      • chcgC
        chcg
        switch to 64 bit for the plugins is just on the way and expected to last some time, e.g. see the description of the compare plugin at github https://github.com/jsleroy/compare-plugin and the latest CI build at https://ci.appveyor.com/project/jsleroy/compare-plugin/build/1.5.7.101 , but that is not mainstream read to use, similar the pluginmanager for x64 at https://github.com/bruderstein/nppPluginManager/tree/x64
        So for N++ usage with plugins 32 bit is still the default for some time.
