    Help me plssssss
    2 Posts 2 Posters 1.9k Views 1 Watching
    • Joao Gabriel Pigini IssasJ Offline
      My numbers are diferent its like 12A(3)4P(5)A(6)K(7) (8)9.
      How can i fix this ?
      • Js jSJ Offline
        Js jS
        put the cursor to the beginning of text, just before the “1”
        press the delete key 24 times
        those awful numbers should be gone
        hope this helps
        seriously … you did not describe the problem at all
