    Notepad++ and laptop with more displays issue - Notepad++ is forced to move to default one sometimes
    8 Posts 3 Posters 4.2k Views 3 Watching
    • Jakub ŠenkJ Offline
      Jakub Šenk
      I have a problem with Notepad++ on a laptop with more monitors connected. When I have opened Notepad++ on default display (monitor), everything is OK, but otherwise, I have the problem that during some “random” action in Notepad++, Notepad++ is automatically forced to move to default one. I haven’t been able to determinate, what “action” in Notepad++ cause this problem and I think it is random and frequent.
      Notepad++ is the best editor ever and I have been using it for many years, but this is VERY annoying. I hope so, that my description is understandable and I am sorry for my English.
      Thanks for the help.
      Jakub (James)
        Claudia Frank @Jakub Šenk
        @Jakub-Šenk
        actually I’m not aware of a function, within npp, that does allow moving the application to another monitor.
        I guess this may be related to your graphics card management software. Could it be
        that it provides some kind of functionality and has this assigned to a global hotkey?
          Jakub Šenk
          I am pretty sure that I didn’t press any key before Notepad++ force moving, I just used basic Logitech M185 mouse…
            @Jakub-Šenk
            does this happen while you are working or after relogin or resume hibernate etc… ?
            • Ravi RajalwadR Offline
              Ravi Rajalwad
                Jakub Šenk
                @Claudia-Frank It occurs when I am working with Notepad++ for some time…Have you ever tried to use Notepad++ on a non-default monitor?
                  @Jakub-Šenk
                  in the past, yes, but currently, I only have two laptops and both are setup with Linux anyway.
                    Jakub Šenk
                    @Claudia-Frank
                    make sense. This problem I have only for a couple weeks and on Windows 7. And I think that I tried change mouse with completely different one (different producer…) and I had the same problem. I don’t really know what cause this issue and I am sad because of that. I haven’t a similar problem with any other software.
                    Thanks anyway.
