    Problem with ? -> "Set Updater proxy..."
    8 Posts 4 Posters 18.9k Views 2 Watching
    • ArfyFRA Offline
      ArfyFR
      On work, I have to set a proxy and I wanted to also set in n Notepad++ for program updates.
      (I don’t have the problem with the plugin manager…)
      But
      • in “?” menu,
      • then “Set Updater proxy…”
      • if I set it, “Ok”,
      • then reopen it,
      • it is back to “0.0.0.0”
      I had the problem with previous version and also the new one 7.3
      Claudia FrankC 2 Replies Last reply Reply Quote 1
        Claudia Frank @ArfyFR
        @ArfyFR
        don’t have the issue here (using also latest 7.3).
        Could you provide ?-debug->info, please.
          @ArfyFR
          value is saved in C:\Program Files\Notepad++\updater\gupOptions.xml
          could it be that you have write permission issues?
          • Andrew RaisonA Offline
            Andrew Raison
            Hi, I have noticed this same issue. I do not have a gupOptions.xml. There is no such file in that folder. There is a gup.xml but this does not have any proxy reference. Thanks. Andrew
              Andrew Raison
              Notepad++ v7.3 (32-bit)
              Build time : Jan 1 2017 - 20:04:42
              OS : Windows 10
              Plugins : mimeTools.dll NppConverter.dll NppExport.dll PluginManager.dll
                Claudia Frank @Andrew Raison
                @Andrew-Raison
                Andrew,
                can it be that you do not have write permissions to that folder?
                As the zip doesn’t contain the file itself, I assume that it gets created when needed.
                Content of the file looks like
                <GUPOptions>
                    <Proxy>
                        <server>127.0.0.1</server>
                        <port>8080</port>
                    </Proxy>
                </GUPOptions>
                maybe create it manually?
                  Andrew Raison
                  I’m a local admin but think the issue may be because of UAC. I created it manually and got a UAC prompt to save it. It can now check for changes. Thanks.
                  Problem is now there is about 10 of us who have it installed so need to push this xml file out to them as well.
                  Thanks again for the assistance, Andrew
                  • Demian AndradeD Offline
                    Demian Andrade
                    Permission issue. Just run C:\Program Files (x86)\Notepad++\notepad++.exe as administrator (right click, run as admin.) and it will keep the proxy settings.
