    How to differentiate ctrl and alt gr
    9 Posts 4 Posters 4.3k Views
    • Aadarsh IndurkhyaA
      Aadarsh Indurkhya
      I am facing an issue regarding differentiating ctrl and altgr key strokes.
      https://support.microsoft.com/en-us/kb/306560
      Following this link i changed my keyboard layout to US international which converts my right alt key to behave as altgr key.
      But my code is currently not able to distinguish between altgr and control key since it is receiving the same messages. In notepad++ it is working fine. Can you please help me with distinguishing these two control messages.
      I m using VK_CONTROL to check for control key press
      Thanks
      • Claudia FrankC
        Claudia Frank @Aadarsh Indurkhya
        @Aadarsh-Indurkhya
        maybe this helps.
        Scott SumnerS Jim DaileyJ 2 Replies Last reply Reply Quote 3
        • Scott SumnerS
          Scott Sumner @Claudia Frank
          @Claudia-Frank
          You are on fire with the LMGTFY answers!
          I hope I never get one of those answers from you. :-)
          • Claudia FrankC
            Claudia Frank @Scott Sumner
            Scott,
            I hope there is no service like
            let_me_correct_your_answer_by_google
            otherwise I think the boomerang will hit me. ;-)
            • Jim DaileyJ
              Jim Dailey @Claudia Frank
              @Claudia-Frank
              Wicked sweet answer! I am amazed at how many people apparently never think of doing even a simple web search.
              • Claudia FrankC
                Claudia Frank @Jim Dailey
                @Jim-Dailey
                ;-) but how did they find this forum?
                There must be a place somewhere pointing to it, with some comment like
                What you always wanted to know - ask there. ;-D
                I need to check google maps - should be easy to find this information sign ;-)
                  Aadarsh Indurkhya
                  can you point it in code how it is handled in notepad++ ( just the filename in the source code will help ) . Because i found out that this is sending 2 control messages successively : one for control ( VK_CONTROL ) and one for alt ( VK_MENU ) One possible solution i can think of is to note the last control message and check the current control message to check whether they are of alt-gr sequence. But i believe a better solution might exist .
                  Regards
                  Aadarsh
                    Aadarsh Indurkhya
                    I solved the issue with GetKeyState method to check the current state of alt key. if you have any other solution please share :)
                    p.s : I found this forum via notepad++ git repo.
                    • Claudia FrankC
                      Claudia Frank
                      @Aadarsh-Indurkhya
                      GetKeyState is the one I would have used as well, I guess.
                      Why do you think npp is checking for AltGr?
                      I assume it isn’t.
                      That’s a good one ;-)
