    find and replace help
    2 Posts 2 Posters 1.8k Views 2 Watching
    • Shawn ThomasS Offline
      Shawn Thomas
      I have about 1500 sets of coordinates that I need to modify. I have a list that looks like this:
      Z = -126.102 mm,
      Z = -126.182 mm,
      Z = -126.187 mm,
      Z = -126.202 mm,
      I would like to find them and replace them all with the same value
      Z = -126.000 mm,
      Very new user and short on time and struggling with the expression. Can also use a find from Z = to a specific column, all the values are lined up.
      Any help would be greatly appreciated.
        Claudia Frank @Shawn Thomas
        @Shawn-Thomas
        what I get is that you only want to modify the decimal part, correct?
        If so, and if your data look exactly like you posted than
        find: \.\d+
        replace: .000
        . means you are looking for the literal dot followed by
        \d+ one or more digits (as much as possible)
        Of course you need to check the regular expression box in find repalce dialog.
