    Replace text with \n\r using regular expression
    9 Posts 3 Posters 8.4k Views 2 Watching
    • Stanisław MędrzeckiS Offline
      Stanisław Mędrzecki
      Welcome everyone.
      At start I have to say, I’m not very advanced notepad ++ user. I know something about regular expressions, but I have to do something what is outside my knowledge.
      I need to replace specific string in every line for new line (<CR><LF>). The problem is that this specific string can be found more than one time in every line.
      Example:
      Original lines:
      ^WCONEX(905,1,“CONDICIONES INICIALES”,10)=TIR=-1#INICIO#
      ^WCONEX(905,1,“CONDICIONES INICIALES”,30)=($E(TIR,2)=“O”)#RECIBE,ACK,INICIO#
      ^WCONEX(905,1,“CONDICIONES INICIALES”,40)=($E(TIR,2)=“R”)#RECIBE,ACK,INICIO#
      ^WCONEX(905,1,“CONDICIONES INICIALES”,50)=($E(TIR,1)=$C(5))#KILL,ACK,INICIO#
      ^WCONEX(905,1,“CONDICIONES INICIALES”,55)=($E(TIR,1)=$C(4))#KILL#
      ^WCONEX(905,1,“CONDICIONES INICIALES”,60)=($L(TIR)>2)#ACK,INICIO#
      How should it looks like after replacement:
      TIR=-1#INICIO#
      As you can see only the first occurence of “=” was replaced with \r\n
      Is here any good soul that will help me and tell how the regular expression should look like?
      Regards for everyone
        Claudia Frank @Stanisław Mędrzecki
        @Stanisław-Mędrzecki
        If I understand correctly you want to find everything until you match the first equal sign, correct?
        This means you need to search in non-greedy mode something like
        This would match anything from the start including the first equal sign
        See here for more details.
        When grouping your parts (before and after the equal sign) und can use the replace options
        \1\r\n\2
        to make it work. (\1 what has matched first, \2 second …)
        So I think you need to have
        for your example. (Note, ^ does not refer to the literal instead it is the anchor for start of line,
        whereas $ is end of line, of course only, if not dot matches newline is activated)
          Stanisław Mędrzecki
          Yeah it looks like I need to find first equal sign and then everything what is on the left from “=” should stay in the same line, and everything on the right should be moved one line down, including removal of this first “=”.
          The main question is: Is it possible to do that in one expression?
          This files have sometimes more than 2000 lines before replacement and the process is sometimes very annoying.
          Now I do that in that way:
          Text to search: )=
          Text to replace: )\r\n
          Then I’m clicking on search, and if correct string is highlighted then replace.
            seems my answer was to confusing, wasn’t it.
            Find: (^.*?)=(.*$)
            Replace: \1\r\n\2
              Stanisław Mędrzecki
              @Claudia-Frank said:
              \1\r\n\2
              OMG! This works great. Thank you very much.
              • Robin CruiseR Offline
                Robin Cruise
                by the way, Claudia what actually does \1 and \2 ?
                  Claudia Frank @Robin Cruise
                  @Robin-Cruise
                  \1 and \2 refers to the matched grouped which is defined when using
                  () in a regex.
                  If you have for example
                  (def)(.*)(\()
                  and a text like
                  def test_func()
                  \1 = def
                  \2 = test_func
                  \3= (
                  More on regex is here.
                    Robin Cruise
                    yes, I understand something now. But if I have something like this:
                    def test_func(.$)
                    \1 = def
                    \2 = test_func(.$)
                    \3= should be only (.*$) But doesn’t work.
                      @Robin-Cruise
                      so you have only one group, means \1 contains everything after test_tunc, unitl line end.
