    Help with modifying .ini Language / Comment Lines
    3 Posts 2 Posters 2.9k Views 2 Watching
    • WildByDesignW Offline
      WildByDesign
      I have what is likely a very basic question, but I have been unable to figure out.
      My usage:
      Language: MS ini file (standard .ini config files)
      Comment Lines: # and !
      Goal: To remove ! from being used as a Comment Line
      • I would like to continue using # for comment lines; but not !
      I like how the Style Configurator has options to make comment lines show as italic font and with different colour for those lines. This is what I would like to continue working for the # comment lines but I simply want to be able to modify the language capability so that lines starting with ! do not show up as comment lines specifically for these .ini files.
      I have spent several hours over the past few days looking through the Notepad++ language files, specifically within the .ini file sections trying to understand how the languages work within Notepad++ but this modifying of language functionality is beyond my knowledge at the moment.
      Thank you for your time.
        Claudia Frank
        @WildByDesign
        this is part of the lexer which is hardcoded and cannot, as of now, be modified
        through setting changes.
        WildByDesignW 1 Reply Last reply Reply Quote 0
          WildByDesign @Claudia Frank
          @Claudia-Frank Thank you for confirming.
