    Top to Bottom instead of side by side
    3 Posts 2 Posters 14.4k Views 2 Watching
    • 3d1l3 Offline
      3d1l
      I have a three monitor setup and one of them is in vertical orientation. I use View -> move/clone to have two views of the same file open side by side then View -> Synchronize to synchronize text scrolling. Is there a way to split the screen so that the windows get one in top of the other instead of side by side, maintaining text scrolling synchronization?
      • dailD Offline
        dail
        Right click the bar between the two views.
        • 3d1l3 Offline
          3d1l
          Excellent!!!
