    Python / Lua Script: Detect if a modifier is pressed when running a script
    60 Posts 5 Posters 75.0k Views 4 Watching
      Scott Sumner @Yaron
      @Yaron and @Claudia-Frank
      Oftentimes I find myself writing a Pythonscript that either acts on text above the caret or below the caret. So I need a way to tell it which way to go. An input box would work, but it slows down one’s “workflow”. Often it is an alternate but related keypress (e.g. F10 runs functionality above the caret, Shift+F10 for below the caret) that I want to use. So what I’ve been doing is having 3 scripts, one “common” one, and two others. The two others are tied to F10 and Shift+F10, and call the common script, telling it the direction.
      So I just wanna say that this thread has gotten me thinking about how to do this cleaner; haven’t done anything about it yet, but definitely thinkin’… :-D
      • YaronY Offline
        Yaron
        Hello Scott,
        It’s good to know an experienced “Pythoneer” like yourself have been coping with this issue.
        Our Claudia is really clever, isn’t she? :)
        Please share with us your preferred solution.
        Best regards.
          Alan Kilborn @Scott Sumner
          @Scott-Sumner
          I don’t know that this thread will be of any help for that kind of key differentiation. I do see how it might work with a toolbar button assigned to a pythonscript, though, but this seems like it isn’t what you want.
          • YaronY Offline
            Yaron
            Hello Claudia and all,
            Thanks again for the script. I appreciate it.
            I’ve slightly modified it so that right-clicking a toolbar button would execute its command.
            Emulating the regular left-click behavior:
            • When the right button is down, the toolbar button is “checked”.
              default
            • The command is executed only when the right button is released.
            If anyone can think of a better way to achieve that behavior, please let me know.
            from ctypes import windll, byref, wintypes, WINFUNCTYPE, Structure, sizeof
            WndProcType = WINFUNCTYPE(wintypes.LONG,
                                      wintypes.HWND,
                                      wintypes.UINT,
                                      wintypes.WPARAM,
                                      wintypes.LPARAM)
            GWL_WNDPROC = -4
            WNDENUMPROC = WINFUNCTYPE(wintypes.BOOL,
                                      wintypes.HWND,
                                      wintypes.LPARAM)
            _g = globals()
            CAPTURE_MOUSE_CLICK = _g.get('CAPTURE_MOUSE_CLICK', False)
            OLD_WND_PROC = _g.get('OLD_WND_PROC', None)
            RIGHT_CLICK_MODE = False
            REAL_RIGHT_UP = False
            class Hook():
                def EnumCallback(self, hwnd, lparam):
                    curr_class = (wintypes.WCHAR * 256)()
                    windll.user32.GetClassNameW(hwnd, curr_class, 256)
                    if curr_class.value.lower() == 'toolbarwindow32':
                        self.toolbar_handle = hwnd
                        return False
                    return True
                def __init__(self):
                    self.toolbar_handle = None
                    parent = windll.user32.FindWindowA('Notepad++', None)
                    windll.user32.EnumChildWindows(parent, WNDENUMPROC(self.EnumCallback), 0)
                    self.oldWndProc = None
                def register(self):
                    if self.toolbar_handle:
                        self.new_wnd_proc = WndProcType(self.sciWndProc)
                        windll.kernel32.SetLastError(0)
                        self.oldWndProc = windll.user32.SetWindowLongA(self.toolbar_handle, GWL_WNDPROC, self.new_wnd_proc)
                        if self.oldWndProc:
                            global OLD_WND_PROC
                            OLD_WND_PROC = self.oldWndProc
                        else:
                            _err = 'GetLastError:{}'.format(windll.kernel32.GetLastError())
                            notepad.messageBox('Could not register hook:\n{}\n'.format(_err) +
                                                'Right-click mode won\'t work',
                                                'Register Hook Failure', 0)
                    else:
                        console.write('no toolbar_handle found')
                def unregister(self):
                    if OLD_WND_PROC:
                        self.oldWndProc = OLD_WND_PROC
                        dummy = windll.user32.SetWindowLongA(self.toolbar_handle, GWL_WNDPROC, self.oldWndProc)
                        if not dummy:
                            notepad.messageBox('Could not unregister hook:\n{}\n'.format(_err) +
                                                'It is recommended to save data and restart npp to prevent data loss',
                                                'Unregister Hook Failure', 0)
                    else:
                        console.write('ERROR no saved window proc found')
            	def sciWndProc(self, hWnd, msg, wParam, lParam):
            		global REAL_RIGHT_UP
            		global RIGHT_CLICK_MODE
            		if msg == 0x0204:		# WM_RBUTTONDOWN.
            			windll.user32.mouse_event(0x0002, 0, 0, 0, 0)	# Left down. WM_RBUTTONUP is sent although the right button is still down.
            		elif msg == 0x0205:	# WM_RBUTTONUP.
            			if REAL_RIGHT_UP:		# Another WM_RBUTTONUP is sent when the right button is released. Process it now.
            				RIGHT_CLICK_MODE = True
            				windll.user32.mouse_event(0x0004, 0, 0, 0, 0)	# Left up.
            				windll.user32.SetTimer(hWnd, 1, 1000, 0);	# 1 == TIMER_ID.
            			REAL_RIGHT_UP = True
            		elif msg == 0x0113 and wParam == 1:		# WM_TIMER.
            			windll.user32.KillTimer(hWnd, 1);
            		return windll.user32.CallWindowProcA (self.oldWndProc, hWnd, msg, wParam, lParam)
            _hook = Hook()
            if not CAPTURE_MOUSE_CLICK:
                _hook.register()
                CAPTURE_MOUSE_CLICK = True
                console.write('registered')
            else:
                _hook.unregister()
                CAPTURE_MOUSE_CLICK = False
                console.write('unregistered')
            Copy and paste the code in startup.py.
            In a script you want to run in two modes, (i.e. left-click and right-click) add modeRightClick = RIGHT_CLICK_MODE and handle it accordingly.
            Since a 1 Sec timer is set to revert RIGHT_CLICK_MODE to False, it’s recommended to add modeRightClick = RIGHT_CLICK_MODE at the beginning of the script.
            Best regards.
            Claudia FrankC 2 Replies Last reply Reply Quote 0
              Claudia Frank @Yaron
              @Yaron
              so you are concerned not seeing the pressed/checked button if right clicking on it, aren’t you?
                @Yaron
                here my solution, not fully error proved and just added without any structure
                but I guess you get the point.
                You need to import another 4 types from ctypes (pointer, c_ubyte, c_int, c_ulong)
                The changed part is
                    if msg == 0x0201: #0x0201: # WM_LBUTTONDOWN
                        global LEFT_MOUSE_CLICK_MOD
                        if wParam == 5: # 0x0001 LButton + 0x0004 Shift
                            console.write('left mouse click while holding shift\n')
                            LEFT_MOUSE_CLICK_MOD = True
                        else:
                            console.write('left mouse click\n')
                    elif msg == 0x0204:
                            class TBBUTTON(Structure):
                                _fields_ = [
                                            ('iBitmap', c_int),
                                            ('idCommand', c_int),
                                            ('fsState', c_ubyte),
                                            ('fsStyle', c_ubyte),
                                            ('bReserved', c_ubyte * 6), # 2 if win32
                                            ('dwData', c_ulong),
                                            ('iString', c_int),
                            LEFT_MOUSE_CLICK_MOD = False
                            _point = wintypes.POINT()
                            result = windll.user32.GetCursorPos(byref(_point))
                            if result:
                                _hwnd = windll.user32.WindowFromPoint(_point)
                                windll.user32.ScreenToClient(_hwnd,pointer(_point))
                                button_id = windll.user32.SendMessageA(_hwnd,
        1024+69, # TB_HITTEST(WM_USER + 69)
        0,
        pointer(_point))
                                _tbbutton = TBBUTTON()
                                bool = windll.user32.SendMessageA(_hwnd,
        1024+23, # TB_GETBUTTON(WM_USER + 23))
        button_id,
        byref(_tbbutton))
                                if bool:
                                    pressed = windll.user32.SendMessageA(_hwnd,
        1024+2, # TB_CHECKBUTTON(WM_USER + 2)
        _tbbutton.idCommand,
        True)
                Seems to work on linux, so should work on windows as well.
                • YaronY Offline
                  Yaron
                  Hello Claudia,
                  Thank you very much for the new code. I do appreciate that.
                  I’m afraid we had some misunderstanding here.
                  With your permission, let’s start from scratch. :)
                  As I’ve mentioned in the first post here, my preferred solution is: right-click a toolbar button to execute its command in “alternative mode”.
                  A simple example: Select and Find Next and Select and Find Previous.
                  I want to have one toolbar button: Select and Find Next/Previous. - Left-clicking the button would find Next and right-clicking it would find Previous.
                  My code (that is: your code slightly modified) works perfectly well.
                  The button is “checked” on right-click and the command is executed on right-up (as the regular left-click behavior).
                  I just meant that my implementation is a bit tricky and I’d appreciate a better solution.
                  windll.user32.mouse_event(0x0002, 0, 0, 0, 0) # Left down. invokes a WM_RBUTTONUP message although the right button is still down.
                  And I want the command to be executed only when the right button is up…
                  Allow me to ask you to run my version and have a quick look at the code. You’ll get it very quickly. :)
                  Thank you.
                  I suppose your new code should make the button “checked”. It does that but the command is not executed.
                  Again: some misunderstanding.
                  I assume the following shorter version is adequate If I put the code in startup.py and I’m not interested in toggling the right-click capture. Is that correct?
                                            wintypes.HWND,
                                            wintypes.UINT,
                                            wintypes.WPARAM,
                                            wintypes.LPARAM)
                  GWL_WNDPROC = -4
                                            wintypes.HWND,
                                            wintypes.LPARAM)
                  class ToolbarRightClick():
                  		if curr_class.value.lower() == "toolbarwindow32":
                  			return False
                  		return True
                  	def __init__(self):
                  		parent = windll.user32.FindWindowA("Notepad++", None)
                  	def registerRightClick(self):
                  			msgConsole = "Toolbar Right-Click Mode Registered.\n\n"
                  		else:
                  			msgConsole = "Error Registering Toolbar Right-Click Mode.\n\n"
                  		console.write(msgConsole)
                  _toolbarRightClick = ToolbarRightClick()
                  _toolbarRightClick.registerRightClick()
                  Thanks again.
                  Have a great day.
                    @Yaron
                    I guess I see now but this misunderstanding shows a way to solve it.
                    When you get the button command id (_tbbutton.idCommand) you are able
                    to execute it via notepads menuCommand function like
                    notepad.menuCommand(_tbbutton.idCommand)
                    so my latest example with the logic like this
                    if msg == 0x0201: # left
                    elif msg == 0x0204:
                        pressed = windll.user32.SendMessageA(self.toolbar_hwnd,
                                                             True)
                        # execute script
                    elif msg == 0x0205:
                                                             False)
                    should do what you want.
                    • YaronY Offline
                      Yaron
                      Hello Claudia,
                      That’s brilliant. Thanks again for your time.
                      If you want the command executed on right-up, move
                      # execute script
                      to elif msg == 0x0205:.
                      Also, you can use windll.user32.mouse_event(0x0002, 0, 0, 0, 0) without a timer.
                      		elif REAL_RIGHT_UP and msg == 0x0201:		# WM_LBUTTONDOWN.
                      Have a nice weekend.
                      • YaronY Offline
                        Yaron
                        Hello Claudia,
                        I had a closer look at your code and it’s really nice. Thanks again.
                        Getting the button ID is certainly the “proper” approach.
                        For the record, here is a shorter mouse_event implementation.
                        			if RIGHT_CLICK_MODE:		# Another WM_RBUTTONUP is sent when the right button is released. Send "Left up" now.
                        			else:	# The right button is still down.
                        		elif RIGHT_CLICK_MODE and msg == 0x0201:		# WM_LBUTTONDOWN.
                        This is PythonScript console when using NPP in a RTL layout.
                        default
                        Reading the LTR output in a RTL layout is obviously inconvenient.
                        @dail has kindly added an option to force LuaScript console to LTR.
                        https://github.com/dail8859/LuaScript/issues/6#issuecomment-270676744
                        https://github.com/dail8859/LuaScript/commit/8fed28f8ffe494c5e68a02010fddcdac4b4d3f74
                        Do you think it would be possible to force PythonScript console to LTR using some code in startup.py?
                        Or would it require some modifications in PythonScript source files?
                        If and when you have some time to think about it, I’d be grateful.
                        Best regards.
                          Hello Yaron,
                          if dails commit solves your issue with lua then I don’t see why we could get this to work with python script.
                          The hard work to find out what needs to be done has been already done by @dail, thank you ;-).
                          So we need to get the window hwnd from python script console (and what about the inputbox?)
                          and change the style parameter for that window. Doesn’t sound undoable.
                          Obviously I tend to solve using a python script but if you prefer I will see what needs to be changed in plugin source in order
                          to make it happen but compiling and testing needs to be done on your site.
                            Yaron,
                            Am I right to assume that you do not only need RTL layout but also RTL reading, correct?
                            Or do you really want to have LTR layout in python script while using RTL layout in npp?
                              Claudia Frank
                              I’m talking about something like this
                              • YaronY Offline
                                Yaron
                                Hello Claudia,
                                Thank you for your patience and kindness. Highly appreciated.
                                And allow me to thank @dail again for LuaScript in general and for the console issue in particular.
                                I assumed it was possible to change PythonScript console to LTR but I preferred to get the right direction by consulting with the expert first. :)
                                And, as usual, you already have the solution.
                                The InputBox in PythonScript is LTR even when NPP layout is RTL (so it doesn’t have to be modified).
                                Obviously I tend to solve using a python script…
                                That would be great.
                                You can change NPP text direction whether the layout is LTR or RTL (View -> Text Direction LTR/RTL).
                                Indeed.
                                The console’s frame and input are always LTR. The problem is the output.
                                Looking at your screenshot, I understand the the issue should be further clarified. :)
                                This is NPP in RTL layout with LuaSceipt console in LTR (perfect).
                                default
                                And this is NPP in RTL layout with PythonSceipt console in LTR (frame and input) and RTL (output - confusing).
                                default
                                I’d like to see the output as you see it in LTR layout.
                                This may further complicate the issue but OTOH it might help.
                                The status bar in both screenshots is LTR.
                                As I wrote to dail, I added the following line in StatusBar.cpp:
                                // Change to LTR. "WS_CHILD & (~WS_EX_LAYOUTRTL)" above won't work because WS_EX_LAYOUTRTL is added AFTER the bar has been created and inherited the RTL layout.
                                ::SetWindowLongPtr(_hSelf, GWL_EXSTYLE, ::GetWindowLongPtr(_hSelf, GWL_EXSTYLE) & (~WS_EX_LAYOUTRTL));
                                after
                                if (!_hSelf)
                                		throw std::runtime_error("StatusBar::init : CreateWindowEx() function return null");
                                So getting the console’s handle (or only the output’s?) and changing the WS_EX_LAYOUTRTL style should work. :)
                                Can SetWindowLongPtr() be used via 'ctypes`?
                                Thanks again and good night.
                                  Claudia Frank
                                  Hello Yaron,
                                  ok and yes SetWindowLongPtr() can be used.
                                  I didn’t came across a windows api function which can’t be used with ctypes yet.
                                  This is a toggle function which sets WS_EX_LAYOUTRTL if not set and unset
                                  if was already set.
                                                            wintypes.HWND,
                                                            wintypes.LPARAM)
                                  python_script_hwnd = None
                                  python_script_sci_handle = None
                                  GWL_EXSTYLE = -20
                                  WS_EX_LAYOUTRTL = 0x00400000
                                  def EnumCallback(hwnd, lparam):
                                      global python_script_hwnd
                                      global python_script_sci_handle
                                      curr_name = (wintypes.WCHAR * 256)()
                                      windll.user32.GetWindowTextW(hwnd, curr_name, 256)
                                      if curr_name.value.lower() == 'python script':
                                          python_script_hwnd = hwnd
                                      else:
                                          if python_script_hwnd is not None:
                                              if curr_class.value.lower() == 'scintilla':
                                                  if windll.user32.GetParent(hwnd) == python_script_hwnd:
                                                      python_script_sci_handle = hwnd
                                                      return False
                                      return True
                                  windll.user32.EnumChildWindows(parent, WNDENUMPROC(EnumCallback), 0)
                                  windll.user32.EnumChildWindows(python_script_hwnd, WNDENUMPROC(EnumCallback), 0)
                                  exStyle = windll.user32.GetWindowLongA(python_script_sci_handle, GWL_EXSTYLE)
                                  if (exStyle & WS_EX_LAYOUTRTL):
                                      exStyle = exStyle & WS_EX_LAYOUTRTL
                                  else:
                                      exStyle = exStyle | WS_EX_LAYOUTRTL
                                  windll.user32.SetWindowLongA(python_script_sci_handle, GWL_EXSTYLE, exStyle);
                                  You have to use SetWindowLongPtr where I use Get/SetWindowLongA as
                                  SetWindowLongPtr has not been transferred to wine.
                                  • YaronY Offline
                                    Yaron
                                    Hello Claudia,
                                    Thank you very much. This is beautiful!
                                    I get the AttributeError: function 'GetWindowLongPtr' not found error.
                                    What should I import from ctypes?
                                    BR
                                      Claudia Frank
                                      Hi Yaron,
                                      you have to use either the ansi or unicode version
                                      Unicode and ANSI names GetWindowLongPtrW (Unicode) and GetWindowLongPtrA (ANSI)
                                      Same is true for Set…
                                      • YaronY Offline
                                        Yaron
                                        Hello again,
                                        I get the same error.
                                        No errors with Get/SetWindowLongA but the script doesn’t work. :)
                                        Thank you.
                                          Claudia Frank
                                          Yaron
                                          can you do an test output to the console (preferred last line of code) and run the script at least two times. Let me check about the Set/GetWindowLongPtrW.
                                          • YaronY Offline
                                            Yaron
                                            Claudia,
                                            I had put the code in startup.py. I’ve now moved it to a separate script and run it twice.
                                            default
                                            I’m not sure what you mean.
                                            Aren’t you tired? Should we continue tomorrow? :)
                                            Thank you.
