    High resolution monitor issues
    2 Posts 2 Posters 3.0k Views 2 Watching
    • Waid HundleyW Offline
      Waid Hundley
      My surface book has a 3K x 2K screen. It seems that notepad++ is not scaling and the icons are small. Plugins also have issues like NppExec Console Filters tabs are cut off. You can only see the top half of the tabs. Similar on the Explorer plug in. Its very difficult to see your filters. Is there anything I can do?
        Claudia Frank @Waid Hundley
        @Waid-Hundley
        a few weeks ago I stumbled over this article.
        As I neither have a high resolution monitor nor do I have Windows I wasn’t able to test
        if it works. So if you want to test it would be nice to let us know the results.
