    Forced to save scratch file in 7.3.3
    4 Posts 4 Posters 2.8k Views 1 Watching
    • canufrankC Offline
      canufrank
      Previously, I would have the ‘new 1’ (and/or ‘new 2’ and/or ‘new 3’) files all with some data in them that I hadn’t saved to a specific disk location. If npp was closed, there would be no ‘Save’ prompt and when npp was re-opened, the temp files would reappear.
      Only if a specific document (e.g. ‘new 2’) was closed would I get a Save prompt and be in peril of losing the data
      Now, npp cannot be closed without Save prompts for all new files with data. I am not a fan of the change.
      Is this part the new session functionality? I see it alluded to nowhere.
      • Steve OwensS Offline
        Steve Owens
        Also wondering about this. The old behavior was a wonderful feature for me. Not a fan of this change, either.
        • chcgC Offline
          chcg
          Issue doesn’t happen to me with 7.3.3. I still can close n++ without saving new modified files in WIN10.
          • frogulaoneF Offline
            frogulaone
            I was experiencing the same issue. I uninstalled and reinstalled from the latest download (my previous version was auto “updated” to 7.3.3) and that fixed it. New unsaved tabs no longer ask to be saved when I close the window.
