    Comment Line and Comment Block starting with same character
    3 Posts 2 Posters 2.1k Views 2 Watching
    • Tristana LutareT Offline
      Tristana Lutare
      Hey all. Appreciate any help.
      I’m defining a language for highlighting, etc. Ran into a problem with Comment Lines.
      A comment line begins with ;
      A comment block begins with ;/ and ends with /;
      How do I use both? If I enter it that way, Notepad++ ignores the comment block. If I leave the comment line blank, then the comment block works perfectly.
      Is there any solution? I’ve tried including a space after the ; but apparently I don’t know how to escape a space character properly?
      Thanks!
        Claudia Frank @Tristana Lutare
        @Tristana-Lutare
        Instead of using comment, use delimiter but make sure the block is defined before the
        line comment
        Tristana LutareT 1 Reply Last reply Reply Quote 1
          Tristana Lutare @Claudia Frank
          @Claudia-Frank
          Works perfectly! Thanks so much!
