    Vertical Edge Shows in Printed Output
    1 Posts 1 Posters 1.4k Views 1 Watching
    • Gary InriG Offline
      Gary Inri
      I had to change the color setting of the vertical edge so that I could see it more clearly. I am now noticing that, since I made the vertical edge a darker color, it now shows up on my printed output. This happens when I have the Print Setting set to “Black on White” as well as “No Background Color”. Is there anyway I can avoid this from happening other than going back to a lightly-colored vertical edge?
      NPP 7.3.3 32-bit on Win7.
      Thank you.
