    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Copy leaded data to clipboard without leading tabs or spaces while document stays the same
    Help wanted · · · – – – · · ·
    • Ben Tuloz
      Ben Tuloz last edited by
      How to strip leading tabs and leading spaces from data copied to clipboard from Notepad++? In other words: I want that the data copied to clipboard won’t include leads that appear in the Notepad++ document itself.
      If you want to make sure you understand my need, I further detailed this with illustration images here.
      Do you know a way to do so?
