Navigation
    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Help with extended search/replace
    Help wanted · · · – – – · · ·
    • Matteo Colombo
      Matteo Colombo last edited by
      Hi, suppose that I have this file:
      dada test1
      daeq test2
      dawf test3
      fawq test4
      aafa test5
      faag test6
      I would get this with replace:
      dada test1
      :example1
      daeq test2
      :example2
      dawf test3
      :example3
      fawq test4
      :example4
      aafa test5
      :example5
      faag test6
      :example6
      How can i had :example(number) between all lines?
      ThankYou,
      Matteo.
      Claudia Frank 1 Reply Last reply Reply Quote 0
      • Claudia Frank
        Claudia Frank @Matteo Colombo last edited by
        @Matteo-Colombo
        3 steps
        First step:
        place the cursor onto the first line first position (or press ctrl+home)
        press alt+c (the column mode editor opens)
        select Number to Insert
        Initial number = 1
        Increase by = 1
        Repeat = 1
        press OK
        Should result in
        1dada test1
        2daeq test2
        3dawf test3
        4fawq test4
        5aafa test5
        6faag test6
        Step2
        press alt+c again (cursor should still be at line 1 position 1)
        select text to insert and type :example
        Should result in
        :example1dada test1
        :example2daeq test2
        :example3dawf test3
        :example4fawq test4
        :example5aafa test5
        :example6faag test6
        Step3 (cursor should still be at line 1 position 1
        press ctrl+h
        uncheck wrap around
        check regular expression
        find what should contain
        (:example\d+)(.+)
        replace with
        \2\r\n\1
        press replace all
        should result in
        dada test1
        :example1
        daeq test2
        :example2
        dawf test3
        :example3
        fawq test4
        :example4
        aafa test5
        :example5
        faag test6
        :example6
        Regular expression for find what: (:example\d+)(.+)
        () means we do have two capture groups \1 and \2
        \1 contains :example followed by one or more digits
        and
        \2 contains the rest including end of line chars
        In replace with we reorganize the string as \2\r\n\1 means
        print the second matching group=\2
        add an end of line char=\r\n
        print the first matching group = \1
        Sounds more complicated than actually is.
        • guy038
          guy038 last edited by guy038
          Hello, @matteo-colombo and @claudia-frank,
          Hi, Claudia ! Of course, your solution works fine, but you certainly noticed, that any number, ending each line, wanted by Matteo, is present twice, on two consecutive lines, didn’t you ? Just a nice case for regexes, only !!
          So,… what about this simple regex S/R :
          SEARCH (?-s)^.+?(\d+\R)
          REPLACE $0:example\1
          Preferably :
          • Move back to the very beginning of your file
          • In the Replace dialog, as Claudia said, uncheck the Wrap around option et check the Regular expression option
          • Fill up the search and replace zones
          Et voilà !
          Notes :
          • As usual, the (?-s) modifier implies that any dot special character which match a single standard character, only
          • The ending part (\d+\R) represents any number, whatever the number of digits, followed by the End of Line characters of the current line. As this part is surrounded by parentheses, it is stored as group 1
          • The middle part ^.+? stands for any non-null text, from beginning of line till the last character, before the ending number
          • In replacement, we rewrite, first, the entire searched line ( $0 ), followed by the string :example, followed itself, by the group 1 ( \1 ) that is to say the ending number, followed by the End of Line characters of the current line !
          Claudia Frank 1 Reply Last reply Reply Quote 1
          • Claudia Frank
            Claudia Frank @guy038 last edited by Claudia Frank
            @guy038
            Hi Guy,
            to be honest, I didn’t think about it but you are right, if this,
            I mean that the number at the end of the line is the number
            which should be used in the “example” line,
            is the case, then your solution is much nicer than mine :-)
            • Matteo Colombo
              @Claudia-Frank
              @guy038
              Thank you so much I wanted this a lot!
              Matteo.
