    'Replace All in All Open Documents' problem in 7.4.1
    18 Posts 7 Posters 15.4k Views 2 Watching
    • Steven SpeirsS Offline
      Steven Speirs
      Hi.
      I’ve encountered a problem in 7.4.1.
      If I open 12 text files (for example) and do a simple ‘Replace All in All Open Documents’ operation (for a text string that occurs only once per document), the status bar in the ‘Replace’ window displays “Replace in Opened Files: 12 occurrences replaced.” but not all occurrences have actually been replaced.
      The number of files which have been modified seems to be random (and the document tab icons indicate which files they are).
      A file seems more likely to have its find and replace operation be successful if I click on its tab first (but I don’t want to open many files and then have to click each tab individually before running a find and replace operation).
      I’ve tried disabling Document Peeker (just in case it was somehow contributing to the problem, being that the tabs seem to be involved) but this made no difference.
      I’ve never seen this problem before and I’ve had to revert to 7.3.3 where the above process works flawlessly every time.
      Anyone else seen this issue? Any ideas?
      Thanks,
      Steve
        Hello, @steven-speirs, and All,
        Indeed, like you, Steven, I noticed that there’s a problem with the global replacement, in N++ v7.4.1. To test it :
        • I downloaded the latest 7z, 32 bits, archive : npp.7.4.1.bin.7z
        • I extract it in a folder C:\ _741, with default plugins.
        • Then, I UNchecked the Enable session snapshot and periodic backup option in Settings > Preferences >Backup
        • In this local folder, I created five txt files, named test1.txt, test2.txt … till test5.txt
        • I inserted the simple string 00000, without any line-break, in each of them and save them
        • Once Npp v7.4.1 started, I opened these five test files, which were, all, UTF-8 encoded
        • I opened the Find in Files dialog ( Ctrl + Shift + F )
          • The Find what: box contained the initial string 00000
          • The Replace with: box contained the string 11111
          • The Filters box contained Test?.txt
          • The Directory contained C:\_741
          • The Normal search mode was selected
          • The Follow current doc. option was enabled, too
          • Finally I clicked on the Replace in Files button, and I confirmed the replacement
        • I then opened a DOS console windows
        • With a DOS visualization tool, I could verify, at the same time, just after replacement, the unique line of the five modified files
        After a first S/R ( “00000” -> “11111” ), with test2.txt as current file, I personally noticed that the two files test1.txt and test3.txt were not modified, although the message Replace in Files: 5 occurrences replaced has been displayed !
        Remarks :
        • As this bug is quite random, you may have to repeat that S/R ( for instance “11111” -> “22222”, then “22222” -> “33333” and so on… ) to obverse the bug :-(( But it does happens, after a few S/R actions, anyway !
        • Even if you open, for instance, the change.log file, and keep it as current file, after some S/R, some of the five test files are not modified !?
        • I test this same procedure with a N++ 7.3.3 version but I could not detect any problem, although I did numerous tests
        May someone else could test if this bug occurs, too, in its configuration, with the latest 7.4.1 version ? Many thanks, in advance !
          Claudia Frank @guy038
          @guy038
          I can confirm that this happens at my installation as well.
          And it affects replace all in all opened documents as well as find in files.
              @guy038 @Steven-Speirs @Claudia-Frank
              I think I’ve found the culprit : Document Peeker.
              Could you disable Document Peeker (uncheck it in MISC section of Preference Dialog) to make sure replace all in
              files works again?
              Thank you.
                Steven Speirs
                Hi.
                Do you mean ‘Document Peeker’? I had already tried disabling ‘Document Peeker’ to no avail. (I noted this in my first post above.) I’ve just tried again with the same results.
                • Installed v7.4.1.
                • Deselected both ‘Peek on tab’ and ‘Peek on document map’ - can still reproduce problem.
                • Restarted Notepad++ with Document Peeker disabled - can still reproduce problem.
                Not sure if this info will help but these are my findings.
                Thanks for looking into the problem.
                Regards,
                Steve
                  Claudia Frank
                  Don, Steven
                  when document peeker settings are unchecked it seems to work fine for me.
                  I tried ~50 times to replace content in 15 open files and it always was replaced in all files
                  but as soon as I check the settings I do see the issue.
                  I guess I even found when it happens - as soon as a peek (?) has been displayed, the content of this
                  document doesn’t get replaced - looks like.
                    Thank you @Claudia-Frank , I have the same result.
                    @Steven-Speirs Could you give me a screenshot to show me how you disable Document Peeker ?
                      Steven Speirs
                      @donho
                      Here’s a screenshot: https://app.box.com/s/osnrj1i9ix2cqi530fobdboeuzns2up7
                        donho @Steven Speirs
                        @Steven-Speirs Yes, I have experienced the same problem.
                        You have to restart Notepad++ after disable Document Peeker.
                        Please restart Notepad++ and check this settings to ensure it’s not active then test.
                        Pleas let me know the result of your test.
                          Steven Speirs
                          Hi.
                          I’ve tried again this morning and disabling Document Peeker does seem to fix the problem.
                          I have no idea what I was doing last night when I thought the problem still existed (maybe searching for text that was not in all files). Sorry for the false alarm.
                          To reiterate: the problem does not exist when Document Peeker has been disabled.
                          Steve
                            @Steven-Speirs Thank you for your confirmation !
                              Hi, @donho, @steven-Speirs and All,
                              Quite strange, indeed ! Finally, I’m, exactly, in the same situation than Steven and I could have writen a similar post to the Steven’s one :-)) But, certainly, in less fluent American-English !
                              So, presently, the features Replace All in All documents and Replace in Files properly work, when Document Peeker new feature is disabled, in N++ v7.4.1 :-))
                              Many thanks, @donho, for your feedback, about that matter !
                              • Gary CollierG Offline
                                Gary Collier
                                issue continues in v7.7.1 both 64 and 32 bit versions
                                I notice when my file contains hex code 85 the all document replace function works on focus document only. When I try with another group of files that do not contain hex code 85 the replace all documents is successful for all. Perhaps this observation might help to reduce the randomness of the underlying issue.
                                • Alan KilbornA Online
                                  Alan Kilborn @Gary Collier
                                  @Gary-Collier
                                  That’s really too vague for anyone to care about pursuing. Why don’t you do something like this:
                                  fileset, all in one folder:
                                  file1.txt - active document when replacement is started - contains hex 85 - what happens to it after replacement operation
                                  file2.txt - doesn’t contain hex 85 - what happens to it after replacement operation
                                  file3.txt - etc
                                  etc.
                                  Nobody really likes typing to describe a problem. BUT…You’ve got to give something to get something.
                                  Prediction: No reply.
                                    Hello, @gary-collier,
                                    First of all, Gary, when you speak of the "hex 85" character, do you mean :
                                    • The Unicode character …, of code-point U+0085, which belongs to the Control-C1 range, of short name NEL ( NExt Line ), and which can be found with any of the regexes, below :
                                      • \x85
                                      • \x{85}
                                      • \x{0085}
                                    when the current encoding of your file is, either, UTF-8, UTF-8-BOM, UCS-2 BE BOM or UCS-2 LE BOM, exclusively
                                    ( Refer to http://www.unicode.org/charts/PDF/U0080.pdf )
                                    OR
                                    • The Unicode character …, of code-point U+2026, which belongs to the General Punctuation script, of name Horisontal Ellipsis, and which can be found with :
                                    • the regex \x{2026}
                                    • the regex \x85
                                    when the current encoding of your file is ANSI
                                    ( Refer to http://www.unicode.org/charts/PDF/U2000.pdf )
                                    Personally, I tried with a local N++ v7.7.1 installation, in folder D:@@\771, containing 3 UTF-8 text files Guy_1.txt, Guy_2.txt and Guy_3.txt
                                    Then, I considered 4 cases, in the Guy_2 file :
                                    • Only letters
                                    • Letters + the U+0085 character
                                    • Letters + the U+2026 character
                                    • Letters + the U+0085 and U+2026 characters
                                    And I replaced just one occurence of a word, per file, with an other one. But luckily, in all cases, I did obtain 3 replacements ;-)), with Filters field = Guy*.txt and Directory field = D:\@@\771
                                    • Hugo AlvesH Offline
                                      Hugo Alves
                                      I am using version 7.8.6 and got the same problem on my first attempt.
                                      But it works properly when i run NP++ as Administrator
                                        Alan Kilborn @Hugo Alves
                                        @Hugo-Alves
                                        You might want to be a bit more specific about what the “same problem” is, after all, this thread is a bit old and several things were discussed above.
                                        Also, while 7.8.6 isn’t “ancient” by any means, maybe try something more recent?
