Help with manually configuring theme
I do not have admin rights on my computer, nor do I have any themes installed. I can’t directly edit styles.model.xml
I would like to set up my default theme to match one of themoes already out there. The problem is when I go into the Styles Configurator, I don’t understand how the information in the XML corresponds to the menu. Example: the second style in the XML is “FUNCTION” and the second is “PREPROCESSOR”
Where do I find these and everything else by going through the Styles Configurator menu system? Has someone already mapped this out?I found FUNCTION and PREPROCESSOR under Language ActionScript and Language autoIt. If say I was matching the Deep Black xml set up, would I have to change the FUNCTION and PREPROCESSOR in both ActionScript and autoIt?
The XML has hundreds of lines and I realize doing this manually will take some time.
Never mind. I figured it out. XML tells you where in Style Configurator to find settings.
