    Help to set point
    4 Posts 2 Posters 2.4k Views
    • Jesus HerasJ
      Jesus Heras
      Hi everyone, thank you for helping me solve the problem that I have. I need to put a point in the middle of a figure of six numbers, without changing the data on the right. The total data to modify is 1689 cells. Find and Replace. For example
      430056;; -105 430.056;; -105
      438900;; -104 438.900;;-104
      Than you very mach
      • Claudia FrankC
        Claudia Frank @Jesus Heras
        @Jesus-Heras
        a solution depends on the layout of the real data.
        If you just have one column of 6 digit numbers than a possible
        solution is
        • put the cursor to the place you want in the first line
        • scroll to the last line (do not move the cursor)
        • press SHIFT+ALT and click with the mouse to the position in the last line
        this activate the column mode - press your dot key - done
        A possible S/R is by using the regular expression
        Find what:
        ^\d{3}
        Replace with:
        $0.
        Done, but as said, depends on the real data.
        • Jesus HerasJ
          Jesus Heras
          Ohhh Claudia Thank you, many thanks from Spain!!!
          The formula works perfectly and press shift + alt… also
          Thank you very much…Have a nice day
          Greetings from Spain!!!
          Jesús!!
          • Claudia FrankC
            @Jesus-Heras
            ¡De nada!
