    Need Help in "Define your language" section
    2 Posts 2 Posters 2.0k Views 2 Watching
    • Anand MohanA Offline
      Anand Mohan
      I’m Adding PL1/PLI language to Npp, in that i need to add the folding for proc statements
      Example code will be like
      abc; PROC;
      statement 1;
      statement 2;
      statement 3;
      end abc;
      the statement 1,2 and 3 may contain “END;” as a statement, so i cannot use "END"as the end-of-fold
      So i need a folding for
      ***; proc;
      statement 1;
      statement 2;
      statement 3;
      end; ***;
      *** can be anything which is procedure name…
      • J Offline
        Jim Dailey
        @Anand-Mohan
        I don’t know PL1, but if it has any type of preprocessing ability like C does, you could do something like this:
        #define procend end
        and then use “procend” in your code. This is not ideal, I admit.
        Otherwise, I think you have to define all the statement N’s you might use as the beginning of some fold (Open:) and add the corresponding number of “end” statements to end the fold (Close:). That is, you can have multiple Open:, Middle: and Close: tokens; just make sure they are in the correct order (first Close: goes with the first Open:, etc.).
