    Certificate required for building Notepad++ ?
    8 Posts 6 Posters 13.1k Views 3 Watching
    • Indigo GullI Offline
      Indigo Gull
      Hello everyone.
      I’ve successfully built Notepad++.exe in Visual Studio from https://github.com/notepad-plus-plus/notepad-plus-plus, and also Boost.
      However when I launch the resulting notepad++.exe I get these 3 fatal errors…
      • Cheking signature of C:<snip>\scilexer.dll - DLL Signature verification failed
      • Library verification failed - Authenticode check failed: signature or signing certificate are not recognized
      • Exception on WM_CREATE - ScintillaEditView::init : SCINTILLA ERROR - can not load the dynamic library
      I assume this is related to https://notepad-plus-plus.org/community/topic/13415/v7-3-3-fix-cia-hacking-notepad-issue ?
      How can I run/debug from Notepad++ source?
      Thanks.
      • dailD Offline
        dail
        Yes Notepad++ does require the SciLexer.dll file to be digitally signed (which only Don Ho can create). So you have two options:
        1. Temporarily comment out the code that checks the certificate.
        2. Use the SciLexer.dll file that comes with the official release of Notepad++. You can also download one of the zip packages from the website (either 32 or 64 bit) and use the SciLexer.dll file from the zip file.
          Indigo Gull
          Thanks dail… was worried I was missing something! Commented out VerifySignedLibrary call and working fine now.
          • KaushaldevyK Offline
            Kaushaldevy
            Hello everyone,
            I had the same issue with the SciLexer.dll and I’ve followed Dail’s kindly suggestion: “Temporarily comment out the code that checks the certificate” ( I commented out the call to VerifySignedLibrary in loadSciLexerDll() function)
            I was able to get rid of the checking the signature and Library verification failed errors. But, I still get the ‘Exception on WM_CREATE - ScintillaEditView::init : SCINTILLA ERROR - can not load the dynamic library error’
            I am new to the notepad++ and really appreciate on any suggestion
            I am using VS2017 (version 15.2), boost_1_55_0 and …\notepadPlus.vs2015.vcxproj project file
            Thanks
              tukune @Kaushaldevy
              PowerEditor\src\ScitillaComponent\ScintillaEditView.cpp
              HMODULE loadSciLexerDll()
              	generic_string sciLexerPath = getSciLexerFullPathName(moduleFileName, 1024);
              //	bool isOK = VerifySignedLibrary(sciLexerPath, SCINTILLA_SIGNER_KEY_ID, SCINTILLA_SIGNER_SUBJECT, SCINTILLA_SIGNER_DISPLAY_NAME, false, false);
              //	if (!isOK)
              //		::MessageBox(NULL,
              //			TEXT("Authenticode check failed: signature or signing certificate are not recognized"),
              //			TEXT("Library verification failed"),
              //			MB_OK | MB_ICONERROR);
              //		return nullptr;
              	return ::LoadLibrary(sciLexerPath.c_str());
                Kaushaldevy
                Thanks tukune. I have attached a Screenshot
                But, even after commenting the verifySignedLibrary call I get the ‘Exception on WM_CREATE - ScintillaEditView::init : SCINTILLA ERROR - can not load the dynamic library error.
                  Claudia Frank @Kaushaldevy
                  @Kaushaldevy
                  you need to make sure that the resulting SciLexer.dll is in the same directory as notepad++.exe is.
                  • SinghRajenMS Offline
                    SinghRajenM moderator
                    Though little late in reply, but no change needed, if you are dealing with debug build (most of developers deals with debug version). Digital signature checking is guarded now.
                    	// Do not check dll signature if npp is running in debug mode
                    	// This is helpful for developers to skip signature checking
                    	// while analyzing issue or modifying the lexer dll
                    #ifndef _DEBUG
                    	if (!isOK)
                    		::MessageBox(NULL,
                    		return nullptr;
                    #endif // !_DEBUG
