    functionList problems
    3 Posts 2 Posters 2.0k Views 2 Watching
    • Gerzson BékG Offline
      Gerzson Bék
      Hi Everybuddy!
      I want to use function list panel to web programming projects. It works fine with php but doesn’t work with js (javascript). If in a php file is a js section (between the <script…></script> tag) it listing the function()s fine, but in a .js file it doesn’t work. If I change the language of a .js file from javascript to php, it works too. I checked the functionList.xml and it seems good. There is a javascript parser and looks good. However i tried to change it with the content of the php parser, but it didn’t work too. So i can’t imagine what is the problem.
      I need this feature because i use often functions in javascript. So it would be a great help for me if anybody help to solve this probleme.
      thanks
      Gee
      • MAPJe71M Offline
        MAPJe71
        See my answer here.
          Gerzson Bék
          This is very good! Many thanks!
          I tried a similar solution, but i wrote it to the ‘javascript_function’ parser with id=58, because the comment line at start of the file says: “Don’t use L_JS (19) use L_JAVASCRIPT (58) instead!”
          So thanks again! It works now.
          Gee
          ps.: Sorry for i started a new thread, but my notepad++ is a newer version and i didn’t check all of the older threads.
