    How to zoom in on white space symbols
    5 Posts 4 Posters 2.8k Views 4 Watching
    • Joseph M Cutcher IIIJ Offline
      I need the tiny black dots in this image (which are white space symbols) to be larger.
      link text
      holding down Ctrl + Scroll only makes the text bigger. not the symbols.
        Claudia Frank @Joseph M Cutcher III
        @Joseph-M-Cutcher-III
        One way to make this whitespace symbol bigger is to use a scripting language plugin
        for example python script and use the funtion setWhitespaceSize from the editor object.
        Python example
        editor.setWhitespaceSize(4)  # 2 is the default
        This function called from a bufferactivated callback could do what you want to have.
        • Scott SumnerS Offline
          Scott Sumner @Claudia Frank
          @Claudia-Frank
          Hi Claudia, I’m confused by that final part of your response as the OP didn’t ask to do this differently for different files/types. For myself, I just .setWhitespaceSize() once in my startup.py and it works forevermore, globally…am I missing your point about this?
          • dailD Offline
            dail
            As @Scott-Sumner pointed out I’ve always had success just setting the white space size during initialization.
            What I’ve done in the past is catch the SCN_ZOOMIN and SCN_ZOOMOUT notifications and use some simplistic mechanism to map the zoom value to an appropriate whitespace size so that it is changed dynamically.
            Note though there is a bug in the version of Scintilla that Notepad++ uses which does not draw the white space exactly centered. This is really only noticeable if you set the whitespace large enough.
              Claudia Frank
              @Scott-Sumner, @dail
              Thx for the hint and alternatives. Actually I thought it is a buffer setting but gave it a try
              and have to confirm it isn’t. But it is a per editor attribute which means, we have to set
              editor1 and editor2 from within startup.py
              editor1.setWhitespaceSize(4)
              editor2.setWhitespaceSize(4)
