    How to delete text after a specific character in each row
    3 Posts 3 Posters 21.3k Views 2 Watching
    • Rana JawadR Offline
      Rana Jawad
      how to delete text after | in each row ( i just showed 3 rows for example )
      string1 | string2
      string4001 | string2668
      string201 | string202
        Scott Sumner @Rana Jawad
        @Rana-Jawad
        Do a regular expression replacement:
        Find-what box: ^([^|]+\|).+
        Replace-with box: \1
        Search mode: ☑ Regular expression -AND- ☐ . matches newline
        After doing this to your data, it results in:
        string1 |
        string4001 |
        string201 |
        The ^ in the regular expression anchors the search to the start of each line. Next one or more non-| characters are matched followed by a |. The characters on the line up to this point are remembered as group #1 by the enclosing parentheses. After this any number of characters is matched out to the end of the line. At replace time, the contents of group #1 remembered before are substituted for the entire line.
        There are a lot of ways to do this with regular expressions. This is just one way.
          Hello, @Rana-jawad,
          An equivalent regex to the Scott’s one would be :
          SEARCH (?-s)(?<=\|).*
          REPLACE Leave EMPTY !
          Notes :
          • The first part (?-s) is a modifier, which forces the regex engine to interpret the dot regex character as standing for any single standard character ( not End of Line characters )
          • The last part .* tries to match any range, even empty, of standard characters
          • The middle part (?<=\|) is a positive look-behind, that is to say a condition which must be true for an overall match
          • This condition implies that the matched range of characters must be preceded by a literal vertical bar ( | ), which have to be escaped with an \, because the | character is the regex symbol for alternation
          • And, due to the empty replacement box, this range of characters, located after the | character, is simply deleted
          However, just note that, with my regex or Scott regex, if some of your lines contains several | characters, any text after the first | character, will be deleted. For instance, the text, below :
          string1 | string2 | string3
          string4001 | string2668 | string1234
          string201 | string202 | string203
          would be changed into this one :
          string1 |
          string4001 |
          string201 |
