    Coding problem
    2 Posts 2 Posters 1.6k Views 1 Watching
    • Daniela VerdeD Offline
      Daniela Verde
      I am trying to insert a picture on my website and i enter the code
      <img scr=“filename.jpg”> and it will not work, also putting the html file and the image file in the same folder on my computer will not work. Please help
      • gerdb42G Offline
        gerdb42
        This forum is about Notepad++, a text editor. For information about writing HTML see https://www.w3schools.com/ for example.
        But you may try to write <img src=“filename.jpg”>.
